Two methods:
a) If you add a new device remote, and this time select Fireplace or Ceiling Fan, you will have a lot more buttons to choose from, and then using the API you can rename the buttons to more closely indicate what the button does.
b) add new device remotes, choosing generic, for each “pair” of buttons - so you’ll end up with 2+ devices in Bond, though the signals from each will be going to a single real world device -
You can change the reps via API, so … The answer is “sort of”?
See also: Sending continuous remote press -
I’ll defer to other community members who actually have Somfy devices
I’ll defer to Bond staff, who may be able to provide insight the next time they drop by the forums.
