Here is what the AK Bond plugin is reporting for both fans (Sofa Fan and Dyno-XL Fan):
I am guessing he should be using the first ID (KSMWDCE75139), not the one that says ID = 1;
------ Sofa Fan -----
ID: KSMWDCE75139 IP: 192.168.0.184 Port: 80 Update: 10 sec
*** Bridge Info ***
BondBridgeInfo HSPI_AKBond.DeviceBondBridge+BondBridgeInfo
target breck-spitfire String
fw_ver v2.6.7.5 String
fw_date Mon Aug 19 14:35:53 EDT 2019 String
uptime_s 639 Int32
make Minka String
model F1001 String
branding_profile MINKA_F1001 String
bondid null
upgrade_http True Boolean
api 2 Int32
_ 15353388 String
extra null
*** Token ***
“…” “…” String
*** Device Info: Dyno XL (1) ***
1 HSPI_AKBond.DeviceBondDevice+BondDeviceInfo
ID 1 String
name Sofa Fan String
type CF String
location Great Room String
template null
actions
TurnOn, TurnOff, TogglePower, SetSpeed, IncreaseSpeed, DecreaseSpeed, TurnLightOn, TurnLightOff, ToggleLight,
SetBrightness, IncreaseBrightness, DecreaseBrightness, CycleBrightness, SetTimer, BreezeOn, BreezeOff, SetBreeze,
SetDirection, ToggleDirection,
List`1
_ ea1dedb0 String
commands null
- 1.BondDeviceInfo.state HSPI_AKBond.DeviceBondDevice+_State
_ 8999f793 String
1.BondDeviceInfo.properties HSPI_AKBond.DeviceBondDevice+_Properties
_ 95fedcf4 String
*** Device Properties: Dyno XL (1) ***
1 Dictionary2[String,Object] (Lenght 5) max_speed 6 Int64 breeze_max_speed 6 Int64 breeze_min_speed 1 Int64 breeze_period 30 Int64 _ 95fedcf4 String *** Device State: Dyno XL (1) *** 1 Dictionary2[String,Object] (Lenght 9)
power 0 Int64
speed 1 Int64
light 0 Int64
brightness 100 Int64
brightness_cycle_phase -1 Int64
timer 0 Int64
breeze 0, 50, 50, JsonArray
direction 1 Int64
_ 8999f793 String
*** Device Commands: Dyno XL (1) ***
1.Commands Dictionary`2[String,Object] (Lenght 0)
------ “Dyno XL” Fan ------
Here is what the AK Bond plug is reporting for the two fans:
‘KSMWDCE75366.Bridge’ (Bond Bridge) - Device Configuration
ID: KSMWDCE75366 IP: 192.168.0.129 Port: 80 Update: 10 sec
*** Bridge Info ***
uptime_s 703 Int32
make Minka String
model F1001 String
bondid null
api 2 Int32
_ 94814eda String
extra null
*** Token ***
“…” “…” String
ID 1 String
name Garden Side Fan String
type CF String
template null
actions
List`1
_ 06b59e9b String
commands null
_ 0d23128c String
_ 7061dadd String
1 Dictionary2[String,Object] (Lenght 5) max_speed 6 Int64 breeze_max_speed 6 Int64 breeze_min_speed 1 Int64 breeze_period 30 Int64 _ 7061dadd String *** Device State: Dyno XL (1) *** 1 Dictionary2[String,Object] (Lenght 9)
power 0 Int64
speed 1 Int64
light 0 Int64
brightness 1 Int64
timer 0 Int64
direction 1 Int64
_ 0d23128c String
