Hey all!
I have the following fan:
Store: Home Depot
Brand: Home Decorators Collection
Product Name: 60in Driskol Smart Ceiling Fan
FCC ID of the remote: 2AQZU-18028
RF Frequency: 304.25
Documentation: Fcc.report
[hr]
I’m not a fan of the included hubspace app (no local control) and it doesn’t play nice with Home Assistant either so I am trying to replace it with a Bond Bridge for the main control source.
I have managed to register the following commands:
Light power on, light power off, fan speeds 0-5 and reverse fan control (have not checked if reverse fan control can be split into summer/winter control).
Thus far the bond bridge seems like a better RF remote than the one that came with the fan, so I’m already a fan. Better in the sense that the fan is more responsive to the bond bridge than it is to the remote (sometimes it misses the remote commands and I have to click it multiple times to get it to work).
Where the bond bridge is falling short is on dimming control, I can’t seem to find a way to record the light dimming command from the remote.
I know the fan has discrete positions for light dimming levels, but the remote only cycles through them when the light button is held down. This would still be acceptable as the solution. When adding the remote originally, I did see a couple of “found” remotes in the database that had dimming features and I think one of them had the right implementation for dimming (where the fan cycled through dimming levels while the app held the signal until I clicked the button again) but other portions of those templates were just broken (fan control or light on/off switching). I figured I’d be able to record the dimming signal but I cannot seem to find the option to record that. Am I missing something?
Next, the fan allows for the light temperature to be toggled through a button. It has 6 discrete temperatures (2700K, 3000K, 3500K, 4000K, 5000K, 6500K) but I believe the signal from the remote just cycles through the temps and doesn’t necessarily have a different message for each temperature. Thus far, I mapped this to the “toggle bottom light” and it seems to work as expected. I was wondering if there was another toggle that wasn’t trying to track an on/off state that I could leverage for this.
I am using a V1 ‘snowbird’ bond bridge so I know there won’t be any more firmware updates beyond what is already on the device so I am hoping to work within the confines of what is available or may e something that could be done on the app side.
Hopefully I’ve provided enough information for you guys to help me out!
PXSS
