I have a generic awning that uses a WSRE101 remote to control the motor. It is a 433.92 MHz RF remote with I believe a rolling code.
Instructions on adding a remote to the awning are here.
It kinda looks like I could use the somy rts awning and put the awning in the pairing mode. It looks like using the “other” option would not let me use a pairing mode.
I don’t believe this is compatible with Bond. I have a battery operated Alpha motor in an internal roller blind, and last they reported back, Bond were having issues trying to get it working. They are a slightly different model number, so there may be hope for you, but if it follows the same approach it could be the same outcome unfortunately.
