Bond Bridge
Model: BD-1000
Bond ID: ZZxxxxxx
Firmware: 2.15.8
When I try to add the remote as a generic device my Bond bridge appears to learn / detect the button press ok, blinking green, but I cannot control the roller blind from the bond bridge / app. If it is of any use a couple of times I did notice the frequency detected by the bridge was slightly different, i.e. 433.xx where xx may vary.
It appears to advertise “The Alpha remote control system applies a 66 rolling code program with 268 million possible combinations which virtually eliminates any chance of programming duplication.”
I’m assuming that would mean it’s not compatible with Bond?
Thanks. We’re taking a look into this now. However the prospects are not good. It not only has a counter and prevents replay attacks, but also has some obfuscation of the rest of the packet. Could be as secure a as a garage door rolling code. Anyways… if we solve it, we will let you know for sure.
Hi, it is possible to connect multiple remotes by pairing them together. By putting the remote in the clone mode. Is it possible to ‘fake’ this copy mode on the bond bridge and that way pair it as a new remote?
For Alpha shades? No. Alpha shades use a rolling code which protects against replay attacks. That means that a cloned signal will be ignored if it was already processed by the receiver in the motor. Will require us to reverse the rolling code.
Hi Dima, Unfortunately after looking into it, Alpha support is not something we will be able to offer in the near future.
I would encourage anyone who wants to see Alpha+Bond support to reach out to Alpha motors and explain very kindly that you’d like to see this integration happen. That could help make it happen .
I have a ‘hub’ like thing from alpha shades. I can put this in pairing mode and connect multiple single remotes to this one. After that I can use that single remote to control the shades of the other remotes. All together, on one single shade. It’s this one: RE203-8C wall mount - Alpha Tubular Motors USA (alphamotors.us)
Would it maybe be possible to copy the functionality of this into bond bridge?
The trouble is, we don’t have a protocol specification for their RF signals.
What may help is sending a polite message to the manufacturer respectfully requesting that they consider compatibility with Bond Bridge. This is particularly meaningful when coming from dealers, but homeowners’ voices are also relevant.
Good news! We have support for Alpha motors in v3.19.x firmware, currently in beta. The stable release is planned for Nov 15th, but some feedback on the beta would be amazing.
After getting the new beta installed I was able to pair my Alpha motor. I have a WSRE301 remote for a battery powered motor.
The setup wasn’t the smoothest for me, it took a few attempts before it took hold, but I suspect that has more to do with me and the motor, rather than anything Bond can deal with, although… One tip is that, for my remote at least, the pairing (jogging) process was actually pressing the programming button multiple times in quick succession, rather than holding it down. It may be worth including some reference to this in the app during the pairing process.
I also managed to get it into (I think) the limit setting or My position setting mode somehow. It only moved in small increments when using the open and close, but that is the case at the moment for both the remote and Bond, so I suspect Bond is working fine, I just need to look up the manual or online for how get it back to normal.
EDIT: Item 4 in this PDF helped get me out of “Step By Step Mode”:
Overall very happy to have the last of my blinds able to be automated. Great job!!
