Is this motor part number compatible with Bridge Pro?
Thanks.
Online data
AI Overview from Gemini 3.5 Flash
Yes, Vertilux VTi Celtic 433.92 MHz motors work with Bond
, but you generally need the Bond Bridge Pro rather than the standard base model. [1]
Compatibility Details
- Frequency: Vertilux Celtic motors operate on 433.92 MHz, which is within the frequency range supported by Bond hardware.
- Standard Bond Bridge (BD-1000): Does not support bidirectional Vertilux motors.
- Bond Bridge Pro (BD-1750): Is required for proper bidirectional support and communication with these motors. [1, 2]
What You Need to Know
- Check your specific motor series code (such as the 6-700-DM drapery or tubular lines) to confirm if it uses bidirectional RF signaling.
- If it is a bidirectional Celtic motor, make sure you are pairing it with a Bond Bridge Pro for reliable command execution. [1]
