I purchased the bond bridge to control 4 roller blinds in the lounge.
Very easy setup and pairing everything setup in under 15 mins great work all.
My Somfy remote was the 5 channel Situo 5 RTS Pure.
I also have a Martec Revolution Roman blind. Once I found out how to set the blind in pairing mode I used the UNIQUE preset after trying each one in turn and got a successful pairing. This now replaces a DD2702H remote.
Can you elaborate on the Martec blind a bit? The blind has to be in pairing mode then pair it as a Somfy blind? Or pair it is an âotherâ blind?
The remote with the DD model number is a Dooya remote. Try the âDooya Bidirectionalâ technology in the app.
Hi, I also have blinds that use the DD2702H remote. I have tried a few different templates, including the Dooya Bidirectional one. The P2 button on the remote jogs the blind, but the pair button on that app does not. Does anyone have any ideas?
