Hi, I’m about to get about 25 somfy Altus 28 motors and just wanted to double check if I can pair them with bond bridge pro without remotes.
Seeing if I can save cost on the remotes as I’ve been quote about $850 for all the remotes and just spend abit more on the bond pro without purchasing the remotes.
Sure. These motors are RTS and so should work fine with Bond Bridge Pro. You can in fact use the “Virtual Remote” option in the app, but I’d recommend having at least one RTS remote on hand.
The usual way would be to use the VRC after adding the device, but you can fake it to access the controls.
Maybe using 2 phones would be a better way to achieve this.
