I used to be able to add a new Alta Bliss shade (Amp motor) and then Edit the controller to allow a slider (0-100) control so that home automation can set the slide to any position from 0 to 100. Since the spring of 2025 a software release seems to have broken this. Now, when you enable the “set position” slider and hit save, you get an error that the “an error occurred while communicating with the Bond bridge”. This never used to happen. I opened a ticket but it’s been ignored. This is extremely frustrating because it isn’t a new feature that I’m asking for. I’m asking Bond to fix what they broke
