Louvre with Yet188 remote, not working properly
Hi,
Trying to get some louvres (large metal blinds) to work with my Bond Bridge Pro.
They have this remote, https://www.yetremotecontrol.com/products-detail-164104 , had to do some google searching to find it.
The problem is that you have to hold the up or down button on the remote down until the louvre moves to the desired position.
I can teach the Bond Bridge the correct command, but it only send the command for less then a second. I can hear the louvre engage, but after most button presses via the Bond Bridge it doesn’t even move. I would have to press the open command about 20 times for it to open maybe half way.
As I can’t find the remote in the “add a new device” list, I used “other” when trying to program it.
What do I do to get this working?
Thanks
If you would like to attempt sending the signal for longer (I believe Bond staff have indicated an upper limit of 20 seconds), see Need to hold/repeat RF signal for a few seconds.
Specifically post #17
