I don’t remember exactly the time this started happening - several months ago possibly around the time the app update happened.
We have a fan (with light) and a fireplace controlled by a first gen Bond Home. It is added in Alexa. It worked PERFECTLY for YEARs.
Now, my Android Bond app works fine.
Wife’s iOS app sees all the devices but it can’t control them. There is perpetual SYNCING status that never ends.
The Alexa voice control has also stopped working. Alexa can see the devices but can’t control them - gives a ‘device is not responding’ message.
I didn’t change anything (except Bond app seems to have updated on both devices)
I have reconnected the Bond skill in Alexa
I have logged out/in in the iOS app
I’m at my wits end here. I’ve always been a huge fan of Bond because it was a perfect example of ‘it just works’. But I’m a pretty tech savvy person and I can’t figure out what the problem is.
Since Android can still control the devices, a useful comparison would be to test it once on mobile data with Wi-Fi off, then compare with the iPhone on the same Wi-Fi and on mobile data. Does Android still control them away from the home network, and does the iPhone stay on Syncing in both cases? Also, are both apps signed in to the same Bond account, and what are the iOS, Bond app and Bridge firmware versions? Those results could help support distinguish a local-network difference from an account or cloud path issue. Please leave account codes, passwords and serial numbers out of the public reply.
Thanks for testing both phones. The fact that both fail off Wi-Fi while Android works locally points to a possible bridge-to-cloud path problem, but doesn’t identify the cause of 408 or necessarily explain the iPhone’s local syncing issue.
For the iPhone side, could you check Settings > Privacy & Security > Local Network and see whether Bond Home is listed and allowed? Apple documents that this setting controls an app’s local-network access. If it is already allowed, leave it as is and note the iOS and Bond app versions.
For the off-Wi-Fi failure and Alexa, Bond support’s error-code guide asks for the exact error, phone/app version, connection type and whether the Bridge appears online. I’d send them those results and firmware v2.17.4.3 privately; avoid posting the serial or account information here. I wouldn’t reset or remove the bridge while Android still works.
Thanks for the detailed report, and for testing both phones on and off Wi-Fi. That made this much easier to track down.
Got some investigation done here, and it looks like your bridges stopped talking to our cloud right after their firmware update in early October. Your Android phone still works because it talks to the bridge directly over your home Wi-Fi, but Alexa and the app away from home depend on that cloud connection, so they stopped at the same moment.
This is a bug on our side, not something you did. It affects some older Bond Bridges that were set up years ago, and the firmware update exposed it.
The fix is a “Green Reset” and then setting the bridge up in your account again.
You can do the reset from the Android app (Bond Settings > Remove Bond Bridge > Forget Network Settings), or by pressing and holding the Reset button until the Bridge flashes green. Then set it up in your account again, preferably with the Android phone.
No devices or settings should be lost in the process, only the Wi-Fi credentials. If you use the bridge’s local token somewhere (Home Assistant, for example), it will change, so you’ll need to update it there.
If that doesn’t work, let me know in a DM, and we can try other options.
Sorry for the trouble, and thanks for your patience!
That’s the one thing I should have just tried, but I didn’t know how much stuff about my devices it would forget. But it fixed all of the problems at once!!
This has been one of my favorite ‘just works’ devices all these years and I appreciate the support! Well done.
