HomeDepot/Carro fan does register speed buttons
@endy - Device has been working on sporadic basis however it will not keep the last speed. Only light works consistently JUST ONCE then failed.
To make this less miserable I replaced the fan with a different one and all seems to be well now.
This can be archived.
I can definitely open a new topic if needed.
Here’s a link to new fan
Challenge with this new install is there are just 6 speeds available while fan itself has 9 speeds. After programming I find that when fan is set to ‘6’ using Bond, that is in fact 66% speed. Is it possible to add 7, 8 & 9 for this remote? Remote uses template of RCF98v2 as indicated in Bond app.
Fan remote has FCC ID - CHQ7225T and IC ID - 2968A-7225
