@merck@jacob - reaching out to you to see if this is something that Bond supports and works
Finally got this to take commands and works half way.
Though there are buttons on remote except for speeds 1 thru 6 nothing works.
With 433MHz remote I expect this to be in the database to pick up all commands. I even got new fan with new remote but still no dice.
ZZCJ09818
Remote has 6 speeds
3 light levels (L/M/H)
I have been trying for past couple of weeks, finally this morning it took command for all 6 speeds and nothing else.
Attached is picture of remote front in case you need it.
so we’ll look now overall your June recordings and try to goto “bits hunting”
i’ll reply here progress.
will it be ok from your side that we send directly to your app a test device?
you can rename/delete them,
its just that we can see how your fan responds to it.
Device names will be “TestFan…”
that way we’ll try to solve your case asap.
Hope all is well. Haven’t seen any devices, yet. If you haven’t pushed it no worries, otherwise wanted to let you know that no new test devices are showing.
I looked at your recordings, cant tell the full logic of the remote control.
lets start with a simple recording, of the ON/OFF button
if you can, please create (+) a new fan (you can delete it later)
when you see “ADVANCED SETTINGS” please set signal type : RF , Frequency 433.9
then record the ON/OFF button (when bond turns green you can release the button)
then record again (to get the other command, if it was OFF, now it’ll be ON for ex)
yes because I didn’t know which was which - ok noted.
now lets continue,
can you do the same recording for Light ON/OFF ?
meaning - not light dim level - only light ON/OFF
in order to do that, when BOND start blinking blue for recording,
pls make sure you press the remote light button not more than 1 second
(or else we’ll get the dimmer code)
to make sure Bond doesnt need to scan for frequency,
please set frequency to 433.9
you do this by tap “ADVANCED SETTINGS” that you’ll see during the recording session.
i have similar remote fan that I got installed today. Remotes are identical and each remote controls correct fan. I was able to add this fan however it does not seem to be available in the database that Bond keeps.
At present my firmware version on Bond is at 2.17.4-1-g29bc8b4.
New fan is named Ankit - A while old fan that has all the buttons working is Office - O. Is it possible to copy all the commands from Office - O to Ankit -A? I am only able to program certain functions on Ankit - A fan that got installed today, while others don’t even exits as in Light Low, Light Medium & Light high
Please help and if you need to send a test device as you did in the past feel free to send it over
