Help Adding Harbor Breeze 52" Ceiling Fan (FCC ID: 10924A-TX015) to Bond Bridge
Hi everyone,
I’m trying to add my Harbor Breeze 52-in 3-Speed Ceiling Fan to my Bond Bridge, but I’m running into issues and hoping for some guidance.
I’ve tried all the suggested FCC ID–based remotes in the app, but none of them match my fan’s functionality. Some partially worked, others had way more functions than my actual remote.
I also attempted raw recording of each button. Bond Bridge successfully captured every command, but none of the learned signals actually control the fan when I test them.
It looks like my remote is RF-based and responds to approximately 433.850 MHz, but even with that in mind, I haven’t been able to find a compatible profile or make raw recording work.
The FCC ID on the remote is 25A-TX015.
Has anyone successfully paired a Harbor Breeze fan using this remote?
Is there a known compatible model or workaround for this specific FCC ID?
Any help would be greatly appreciated!
