Firmware Upgrade Fails with error 0x180011
I keep getting this error right before the Download even starts. I’ve rebooted the Bond and tried again with no luck. I’m using the latest beta app on the latest version of Android Pie (June Patch) on an original Pixel. Bond serial number starts with BB
Could you try “WiFi resetting” the Bond and trying again? By that I mean: hold down the pinhole button until the light flashes green again and go through WiFi setup. The upgrade flow is a bit different here.
If this fails, I recommend downgrading to the previous version of the app. In the near future, we’ll be releasing Beta versions of the firmware through the V2 app — the experience should be much more stable.
