Thanks for your thoughts @residualimages
I bought the Bond Bridge purely to control my fireplace, and as this is one of the last hurdles I have in my smart home automation journey I am hesitant to swap everything else over into a new platform when I have everything else working perfectly as-is.
Regarding the dangerous aspect of controlling a fireplace, I would not suggest deviating from what the manufacturer has implemented. Instead, what I have suggested simply mirrors what the original design from the manufacturer was, which is to send an âonâ command every 1min IF the fireplace has been placed in an âonâ state. If the fireplace is in an âoffâ state, or any other command is pressed randomly (such as âupâ, âdownâ, âlowâ, âhighâ, etc.), then this should not cause the âonâ command to repeat, as the âonâ state should be explicitly triggered for this keep alive function to work.
Speaking of safety measures as well, no one should be using automated controls with fireplaces that donât at least have remote control support natively featured. It is clear that there are additional safety measures in place for remote control operated fireplaces that help mitigate risks that deviate from standard operations, which is why I have encountered things like the automatic shut-off feature that occurs after no command has been received for 30mins (which would include the âonâ command it expects to receive every 1min). These are safety measures baked into the fireplace itself, and act separately from the remote control.
On the flipside, if the remote control can send this command indefinitely as long as it has battery charge, then I see absolutely zero difference in the Bond Bridge mirroring this functionality, as the internal safety features on the fireplace itself will remain active regardless and as far as the fireplace is concerned nothing has changed at all.
However, to play it safe, I would probably recommend that a 24-hour restriction be enabled on this âkeep aliveâ feature, which would greatly eliminate this concern as it would be an improvement over any manufacturer implementation to begin with. So, in this case, after 24 hours have passed for a fireplace being in the âonâ state, cease the repeated âonâ commands from being sent and send an âoffâ command to turn it off. If the user wishes to restart a fireplace after 24-hours of continuous use, they can safely and easily do so by using the Bond Bridge app as usual.
If Bond would rather, they could add an app reminder âAre you still there?â after 23 hours that checks whether the fireplace needs to be on any longer, but Iâm just focused on getting the basics right so I can get this up and running sooner while itâs still cold and relevant for me. ![]()
