Installed about a months ago and it was working fine until today but now it has a yellow circle.
Rebooted - same thing.
Green reset to try to reconnect to router - app says “Syncing”, then “Unreachable”.
For grins, I tried adding a new Bond Bridge (without deleting the current device - don’t want to have to set up devices in Bond and Homeseer again if not necessary). The app finds the device (same Bond ID as the one currently installed). If I try to add it, the app cycles saying “Connection successful” then “There was a problem communicating…”, but then clears the screen and tries again. Rinse, repeat…
Router config has not changed and no issues with the umpteen other devices connected to it. Bond firmware is 2.14.5.
Any thoughts?
