Hi there! tl;dr: Are there any known wifi AP settings that would cause a Bond Bridge to regularly disconnect from the network, and stay disconnected until rebooted? I’ve tried searching the forum for previous threads, but haven’t quite found anything that fits or fixes the issue.
My Bond Bridge will, after a few days, lose its connection to my router and then refuse to reconnect until I reboot either the Bridge or the router. Whenever this happens, I see this in my router’s logs:
Apr 22 08:53:27 wlceventd: wlceventd_proc_event(662): eth6: Disassoc F4:4E:38:1C:3F:50, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Apr 22 08:53:31 wlceventd: wlceventd_proc_event(685): eth6: Auth F4:4E:38:1C:3F:50, status: Successful (0), rssi:0
Apr 22 08:53:31 wlceventd: wlceventd_proc_event(722): eth6: Assoc F4:4E:38:1C:3F:50, status: Successful (0), rssi:-28
Apr 22 08:53:46 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind F4:4E:38:1C:3F:50, status: 0, reason: Disassociated due to inactivity (4), rssi:-34
Apr 22 08:53:46 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind F4:4E:38:1C:3F:50, status: 0, reason: Previous authentication no longer valid (2), rssi:-34
Email support suggested enabling a guest network and connecting my Bridge to that AP instead to see if that fixed the issue—and that worked! But I don’t really love it as a long-term solution, and now I’m trying to figure out what settings on my usual 2.4GHz network might be causing the issue.
Some hopefully helpful facts:
- The router is an ASUS RT-AX86U.
- No other devices on my network have this issue.
- The Bond Bridge is sitting a few feet away from my router, in line of sight.
- I can’t say after exactly how many days/hours the issue happens, but it’s weekly.
- Unfortunately, the Asus router doesn’t expose the guest networks’ settings, so I can’t compare it to my usual 2.4Ghz AP.
Would appreciate any help or insight people might have. Thanks!
