I have had my Bond Bridge setup and working mostly without issue for over 4 years. Today The unit was stuck red after many reboots, so I started with a green refresh and tried to connect it to the wifi network with no success. I then sadly had to factory reset but this has even not worked. I found instruction on how to get into Bond cli - I can communicate with the device on my network and even was able to force an update to the beta version of the firmware. My issue though is I cannot add the bridge into my app and therefore cannot add back all of my devices.
When I run the live logs on Bond cli I receive the following info:
330363: [0600008f9a45885a HTTP-STA PUT 200 U /debug/livelog] {"ip":"xxx.xxx.x.83","port":37417,"_":"00343898","__":"00343898"}
330364: [0600008f9a45885a HTTP-CLI PUT 200 U /debug/livelog] {"B":"AJ11291","d":2,"v":"v3.3.13-beta","t":"debug/livelog","i":"0600008f9a45885a","f":4,"s":200,"m":2,"x":"http","b":{"ip":"192.168.1.83","port":37417,"_":"00343898","__":"00343898"}}
340811: aws_iot:199 : ERROR: aws iot error: failed
! mbedtls_net_connect returned -0x52
340811: TS_AWS:236 : ERROR: error connecting to mqttInitParams host url: Error(-23) connecting to a2o6q0uz8dqj02.iot.us-east-1.amazonaws.com:8883
363645: TS_HTTP:345 : INFO : HTTP GET /v2/devices/18ef2ab1/state
363646: [ff42bf00ef50847f Anon-STA GET 0 D /devices/18ef2ab1/state]
363646: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
363646: [ff42bf00ef50847f Anon-STA GET 404 U /devices/18ef2ab1/state]
363649: TS_HTTP:345 : INFO : HTTP GET /v2/devices/2f7ad827/state
363650: [ff42bf005e9ca880 Anon-STA GET 0 D /devices/2f7ad827/state]
363650: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
363651: [ff42bf005e9ca880 Anon-STA GET 404 U /devices/2f7ad827/state]
363981: TS_HTTP:345 : INFO : HTTP GET /v2/devices/76c290bf/state
363983: [ff42bf005dc563a3 Anon-STA GET 0 D /devices/76c290bf/state]
363983: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
363983: [ff42bf005dc563a3 Anon-STA GET 404 U /devices/76c290bf/state]
363985: TS_HTTP:345 : INFO : HTTP GET /v2/devices/4267e1ac/state
363986: [ff42bf00768666de Anon-STA GET 0 D /devices/4267e1ac/state]
363986: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
363987: [ff42bf00768666de Anon-STA GET 404 U /devices/4267e1ac/state]
363994: TS_HTTP:345 : INFO : HTTP GET /v2/devices/18ef2ab1/state
363996: [ff42bf0004828d19 Anon-STA GET 0 D /devices/18ef2ab1/state]
363996: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
363996: [ff42bf0004828d19 Anon-STA GET 404 U /devices/18ef2ab1/state]
364053: TS_HTTP:345 : INFO : HTTP GET /v2/devices/76c290bf/state
364054: [ff42bf0078e80f60 Anon-STA GET 0 D /devices/76c290bf/state]
364054: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
364055: [ff42bf0078e80f60 Anon-STA GET 404 U /devices/76c290bf/state]
364056: TS_HTTP:345 : INFO : HTTP GET /v2/devices/2f7ad827/state
364057: [ff42bf0023c53a78 Anon-STA GET 0 D /devices/2f7ad827/state]
364057: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
364058: [ff42bf0023c53a78 Anon-STA GET 404 U /devices/2f7ad827/state]
364059: TS_HTTP:345 : INFO : HTTP GET /v2/devices/56bcddc8/state
364060: [ff42bf00e9365be3 Anon-STA GET 0 D /devices/56bcddc8/state]
364061: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
364061: [ff42bf00e9365be3 Anon-STA GET 404 U /devices/56bcddc8/state]
364377: TS_HTTP:345 : INFO : HTTP GET /v2/devices/56bcddc8/state
364378: [ff42bf00bd777a96 Anon-STA GET 0 D /devices/56bcddc8/state]
364379: TS_HTTP:621 : WARN : token provided in HTTP header is invalid
364379: [ff42bf00bd777a96 Anon-STA GET 404 U /devices/56bcddc8/state]
371804: aws_iot:199 : ERROR: aws iot error: failed
371805: TS_AWS:236 : ERROR: error connecting to mqttInitParams host url: Error(-23) connecting to a2o6q0uz8dqj02.iot.us-east-1.amazonaws.com:8883
The weird thing is that according to my router, my device is supposed to be xxx.xxx.x.89…any ideas?
