Alpha RE302 blind remote
Hello all.
I have purchased a new Bond bridge BD-1000 to control my ceiling fans and roller shades.
I set up a Somfy roller shade with no issue.
When trying to set up my Alpha RE302 roller shade remote, I cannot get it working.
Instructions are to “Press and Hold the motor PROG button until shade Jogs or blinks”. The Remote diagram on the app for the alpha blind is different to the Alpha RE302. The 302 has a button at the rear which I assume is the PROG button, but unfortunately, I cannot get the blind to jog when using this button.
I have tried “Other” for set up and even though it recognises the blind the open and close buttons do not work.
Any ideas on how to set up the Alpha RE302 remote?
Thanks heaps in advance.
If you already have a “manual” remote setup, then you can use that to get the motor into “pairing mode” (i.e. get it to jog). I used method 3 here: https://www.alphamotors.us/wp-content/uploads/2018/02/WSER-universal-motors-cheat-sheet.pdf), which then allowed me to pair the bond bridge.
