Note: Unless you have a Ronco or Bofu issue, I’m not recommending this beta. We intend to release it to stable on ~Thurs anyways. Just sharing the release notes as per our standard practice as we work with some customers with Ronco/Bofu schedule or group issues.
What’s Changed since v4.4.7.1
Bug Fix
- Fix issue where BBP on Ethernet setup mode would pulse blue instead of staying solid green as expected. This was causing a lot of confusion and leading dealers and our staff to think that the Ethernet was not working, when it turned out just to be an issue with the LED software.
Shade Support
- improvement to Alpha control
- Virtual Remote Control now supported for Bofu technology
- add support for Bon AM motor (RMS163)
- solves a problem for Tilt-Only Levelor blinds (now we use SetPosition signals for Open/Close actions on RMS35 when slider is enabled)
- improve Bofu (RMS76) reliability (by sending 3 signals instead of 1)
- Ronco (RMS136): improve reliability (by sending 2 signals instead of 1)
- add support for Select Blinds Lift&Tilt (RMS352)
IP-IP Integrations
- Troy: add error when enabling without complete config
- HomeKit: fix a crash related to stack overflow
- PowerView: import their scenes automatically
- PowerView: groups move together (when all of same PV type)
- PowerView: fix issue where rooms may occasionally have been discovered as shades
