Hi there, I’ve been using Schedules since v2.14.x and experienced inaccurate dawn and dusk times. As a way of getting around the problem I tried to use the before/after dusk options but this method is limited since I can only schedule up to 3 hours in advance of dusk
I’ve flashed the new firmware but the problem is still there. Do I need to delete my existing schedules and create them again to fix this? Thanks for your help!
Thanks for letting us know you’re finding the astronomical schedules problematic. Can you check the “Time & Location” screen for that Bond or Smart by Bond device? The “Location” needs to be reasonably close to your home in order for the dawn/dusk calculations to be right.
BTW Contact our customer support if you want faster responses and private discussion. Our CS team can look up your device and help debug.
ALSO! We just released v2.15.1 firmware which fixes a problem where schedules would entirely FAIL to fire. But it probably won’t fix an issue where they fire at the WRONG time.
