Hi - I currently have 2 Home Decorators Marlon fans in two rooms, and have a third (different size, same model) Marlon on order.
Immediately after installing the fans, each remote controls both - both on the same setting. Before reconfiguring the remote, I also added the device to my new Bond Bridge - works perfectly, though again controls both fans.
The receiver in the canopy is a MR205A-TR, and the remote is a TR198A. These combos appear to only have one dip switch and a learn button located in the remote, so following the instructions I turned the power off to both fans, flipped the dip switch on one remote, turned the power on to only one fan, and pushed the learn button. This worked, and once I turned the power on to the other fan, each remote controlled one fan. At this point, the Bond bridge still successfully controls the ‘unaltered’ fan correctly as well.
From there, I followed the same setup procedure to add the ‘altered’ remote to the Bond bridge. The button presses were recognized, and the app made a couple of suggestions for remote configurations, but none of them, nor manually controlling the button, did anything on the fan.
Help please!
