Hi, I’ve got two somewhat older (maybe early 2010s) Harbor Breeze ceiling fans, which came with remotes when I bought this house. I’m not sure of the model numbers of the fans but the FCC ID of the remotes is A25-TX013. I see on FCC.gov that this is a remote that uses 315 MHz.
Now the situation is that awhile ago I washed one of the remotes in the washing machine. So the fan remote in the master bedroom doesn’t work (but the fan does work at the wall switch). The identical fan and remote in the second bedroom both work. The A25-TX013 isn’t in the Bond database but I assume it’ll work with a Bond Bridge if I train it with the functioning remote. My question is, will I be able to duplicate that device in the app, ?make modifications to the signal, and have the Bond control the fan in the master bedroom?
Things I’ve tried/noted:
- The remote doesn’t have a learn button
- The remote doesn’t have DIP switches
- I’ve tried adding a new universal remote with a “learn” button and also several other methods (holding the high speed button, holding the off button, holding the light button, holding several combinations of those buttons)
- I’ve looked at the receiver unit in the master bedroom fan and it doesn’t look like there’s a learn button or any DIP switches in that either, although I can’t fully visualize it without taking the entire unit down from the ceiling (the installer seems to have used pretty permanent adhesive on the mount).
Thoughts?
