Is there a way to transfer an account to a different email or login?
Can you invite someone else in to access the account?
Bond Bridge Pro, used my email to setup, now need to hand it off for various reasons.
You can remove the Bridge from your account without wiping, and then the new user can set up the Bridge on their account. The account code is programmed into the bridge during this setup process with the app. Note that Devices, Groups, Schedules, Scenes etc will be preserved. (Unless you wipe, then you’d have to start over.)
Does that help at all?
Do I have to remove the bridge from my account first? yes this definitely helps.
You could remove via the app from your account, or you could hold down the button until the light ring goes green which will remove from network and account without wiping data.
