Sunsetter Lights
Anyone have luck setting up the Sunsetter lights with the bridge? I tried pairing it the same way as the awning, using the remote and pairing button, but it doesn’t work. I also tried pressing the on button close to the bridge but nothing works.
I was able to set it up as a second awning, rather than as a light. It works but the UI is awkward (open and close the light) and I don’t believe the dimmer functionality works.
I can try that but would really like to be able to set the % for dimming. It’s a somfy lighting solution so it should work setup as a light. I reached out to my local sunsetter rep to see if they have any suggestions.
You might try the “Somfy Light” option.
I tried that but does not work. It only tries to pair for a brief second after I hit the pairing button on the app.
