Does the Bond BD1000 need to broadcast its SSIS after setup? If so, can you adjust it SSID CH?
Thx!
What is “SSIS”? Do you mean “SSID”?
And, may I ask, why do you care?’
I will guess that you’re concerned about interference with other 2.4 GHz systems. I will note that we had an issue on Bond Bridge’s with serial number starting ZZ on firmware before v2.20.11 where they would use 40 MHz bandwidth and random channel (1,2,3,…,11) for their Config AP. — In v2.20.11 we fixed this to 20 MHz bandwith and only channels 1, 6, or 11. This resulted in less noise and potential interference with other 2.4 GHz systems.
