[SOLVED] Bond Hub Won't Find My Wifi (Australian WiFI Channels 12, 13, 14?)
Ok
I will try it, thank you very match
בתאריך יום ד׳, 3 במאי 2023, 16:10, מאת Simon via Bond Home Forum ‏<notifications@bond1.discoursemail.com>:
Thanks to your issue I checked my router (in US) and it ran on auto(3) channel but indicated a outstanding firmware update. After the update the router ended with auto(13) and nothing worked (bond, echo, pixel phone) couldn’t find my wifi only the laptop recovered and saw the wifi and worked. In desperation I rebooted the router and modem and sure enough everything went back to work and the router now showed auto(4) setting. Without your issue I would have likely being stuck for a while not knowing about the channel limitation. THANKS to the bond community!
I almost gave up and throw it away… after I checked with hotspot I saw that the problem is in the router… thanks everybody
בתאריך יום ד׳, 3 במאי 2023, 19:10, מאת Joachim47 via Bond Home Forum ‏<notifications@bond1.discoursemail.com>:
