Hello
I have RF contact door sensors, bond is able to pick the signals. But I’m not able see the state of door sensors with bridge (open/ closed). I wanted to use this with Home Assistant to check the status of the door(s). Would someone be kind to guide me with this issue.
thank you in advance
Bond is not an RF scanner / listener in normal mode (as in, whenever you are not actively scanning to add a device).
It is meant to issue RF / IR commands.
