Is there another option on the market that is bond enabled to switch out AC fans? The Home Depot generic one seems to be discontinued or no longer available.
I have not used this but it looks just like the HD controllers I have.
AND looks like it needs this receiver:
Assuming you mean this one, which I’ve bought and used in the past?
Seems to be out of stock or discontinued, yep.
@merck , do you know if that partner has publicly commented on a new revision / replacement model of an SBB universal kit?
Or if any other partner is offering an SBB retrofit unit?
(I had hoped that this item was a replacement, but it’s a “HubSpace” vs SBB kit)
I’ll check with our partner who sells on HD what the stock situation is.
EDIT: Hang on, it shows as in-stock for me. (?)
Same here. No dice for 77007 or 96761.
I think the only stock available is local store stock.
I ended up finding one on ebay since I couldn’t get one at of Home Depot
I went hunting for another one do upgrade a few more fans but it looks like Home Depot and eBay are both no longer options now.
Any ideas if these will ever be back in stock?
@merck - did you ever get a chance to check with your partner on current stock / future plans (if publicly shareable)?
