Qsys controle integration
Hey there guys I am new to the forum
Has anyone integrated the bond bridge pro with qsys controle ?
Welcome, @Kylebeyond!
I don’t know of anyone on the forums using QSYS currently.
A quick browse around their documentation seems to indicate you may be able to send commands from QSYS to a Bond Bridge (Pro) using what they call ‘Command Buttons’, I believe:
Command Buttons ... Each button will send one specific string, and you can add up to 64 buttons in the component. You can also specify if you’re sending commands via TCP, UDP, or Serial.
It would require a bit of trial and error I would suspect.
hey i have a an integration for the Q-sys platform here.
