Possible to control SmartWings Shades?
To be clear, BD-1000 is a model number that was maintained between the first generation (A/B serials) and second generation (ZZ serials) Bridges. — A marketing mistake we will not make again!
So what matters is the serial number, not the model number in this case.
Ah thanks for the clarification because I looked on the Bond website and saw it was still selling model # BD1000.
My serial number starts with BB.
This worked perfectly for me, thank you! I had paid for the Zigbee controller in several of my smartwings shades, but controlling them through the bond bridge is way more reliable.
OMG. I have been struggling forever with my zigbee shades. I saw this thread and added two rooms as a test. It couldn’t have gone any smoother. Still playing with it but looks very promising. Presume I keep zigbee connection to monitor battery? Not sure what else I need it for.
I really wish Bond would add Smartwings to their instructions, now that we know this works.
Following on from this life changing shade control event, I was wondering about grouping. Ideally I want to get to the point that all shades in the room open and close at the same time, as it does with the Smartwings remote.
I had previously asked about grouping shades for other blinds I have in the house - Rollerhouse (Is there a way to sync multiple blinds to go up and down together? - #7 by Fofer) and there was talk about an upcoming group capability.
First I thought I could try learning the remote by putting it in all shades mode and then pressing the P button. None of the shades jog. So this doesn’t appear to work.
Then I tried recording the open and close commands from the all shades command. It got the command immediately but didn’t seem to play it back. But I don’t have the Bond hub in the same room. If it is thought that this approach could work I am happy to move the hub and play around with learning the commands.
Master Channel versus Groups
Wonder which of these explanations and options is most applicable to SmartWings?
Groups do not appear to be exposed to Hubitat. Still checking on that but I don’t see anything. Perhaps I can call the API directly to use the group. Looking into that.
Maybe you can get the motors in pairing mode one at a time, each time pairing with one motor. Then you’d add that remote control channel as a “master channel” in the app.
I’m starting to think we really should have a way to associate a master channel with a group so that you can use the highlevel group feature and get hembar alignment even for these manually recorded devices.
The group command does almost achieve this. It seems like it sends out the commands very quickly. The shades don’t open or close at exactly the same time but the difference is definitely in fractions of a second.
Question - does the group check to see if the shades actually do as they are told or simply sends out the commands? I built rules in Hubitat to wrap around the open and close zigbee commands to make sure that it is done. But now that I am switching over to Bond I wondered whether I still need to do that. I do see the odd shade that does open or close in the group every so often.
As of now, Bond Bridge on RF/IR is 100% one-way for control. So, it is fire-and-forget. Ironically, this is sometimes more reliable than the intended two-way control channel. That said, we would like to see 2-way control on the platform where you get real state feedback and an error if the shade is unreachable, but it is not possible with most of the RF/IR devices.
Wondering if anyone has had success with controlling multiple shades on the same channel at the same time. I have three shades that are all on channel #3 of my 5 channel remote. When I press the P button on the remote, those three of my shades jog, but I am unable to then control them from Bond - nothing happens via the app.
Thank you @chadconway! These instructions got my Beasen roller blinds to pair to Bond as well! I’m guessing Beasen and SmartWings must be related or same manufacturer and different brands.
My remote has 2 buttons on the back, doesn’t have the aaa batteries
Tap tech WR06
I tried and the bond didn’t control the blind once I hit the pair button in the app, but I only pressed the button on the back of the remote once, is that the key? To press twice?
Anyone know if I should do the right or left button on the back of the remote?
getting approx 25ft of range on my bond bridge to my smart wings blind, needless to say its disappointing. Any ideas/suggestions?
Hi! Sorry to re-open this but I’m getting a weird issue, I have 2 bonds with multiple Smartwings and some somfy covers on them, nonetheless I’m having problems getting 1 specific shade paired… It works normally from the smartwings remote but never jogs when I try pairing from Bond.
Is there anything I can do to debug this? its weird and a bit of a pain as its the last one in my apt and it wont budge…
thanks!
For anyone with the levitate top down bottom up, pair it the same way with the remote, but select “Wynmotion tdbu” instead of Dooya
Any news on getting official support for Smart Wings? The zigbee control can be unreliable
I have heard that it works using the “Dooya Bidirectional” option in the Bond Home app.
Yeah, but after all this time and interest, why not make it an officially supported integration?
