I have a fan using the Hampton Bay Zigbee controller Model # 68109.
I am not using the Zigbee portion as that proved to be quite unreliable.
Every so often the fan will not respond to any commands. Then I get the Hampton Bay remote out and turn on the fan. It works first go and then the Bond works after that.
I am running firmware 3.21.3.6.
Any logic to this? Thanks.
It has been some time since I set the fan up and I can’t actually remember how I did it. I don’t remember recording individually so I am guessing it was through a template. Assuming that is the case then the next obvious thing might be to try recording the buttons.
However, the idea of flipping the power on and off is a good one as this will let me know if recording the buttons is worth it.
The fan sits idle all winter but gets a workout for the next few months, so will see if it happens again. Thanks.
It should say in the Bond app, under the device page, tap the 3 dot menu, go to Settings, expand Advanced, and see if there is a Template listed:
a-ha - checked it - Template B2
