Release notes for Local API Documentation V2.6.32
- Fix device and command list examples for the Local API, they’re now properly presented as a list of IDs and hashes
- Add
trust_state, allowing a user to define the Bond’s behavior when it receives a request that does not match its state - Remove WiFi config flags (
"static_ip_set"etc.) on PUT tosys/wifi/sta. They’re still present on GET so that the user may know whether the WiFi configuration has been saved - Move
bluelightto thebridgeendpoint - Add “Smart By Bond” to the glossary
Additionally, some endpoints were documented but unimplemented:
- PATCH state is now implemented
- DELETE
signal/scanis implemented
trust_state (in devices/x/properties) is the big one here, let use know if you have any feedback on this setting! Here’s the description from the docs:
The scenario: the Bond has a “ToggleLight” command, and the Bond believes the light to be on. The user requests the action “LightOn”. If the Bond trusts its state, it will do nothing, as the light is already on, and sending a toggle command would turn it off. If, however, the Bond does not trust its state, it will send the toggle, and believe that now it knows the true state of the physical device.
"trust_state"set tofalseis mostly useful if the user intends to use a physical remote together with the Bond and is the default,"trust_state"set totrueis mostly useful if the user would like to control their device remotely with complete confidence that what the Bond reports is the device’s actual state.
Currently we are defaulting to false but we’re considering defaulting to true…
