Will Smart By Bond devices support the new local API? If so can someone elaborate how this will work?
Yes, Smart By Bond devices expose the same API as Bond Bridges, minus signal-related endpoints and the endpoints under āBridgeā in the docs. The device itself is exposed as devices/1.
Thanks Jacob.
Will it still respond to the devices end-point (which i assume will return a single deviceid)
Assuming /sys/version, /v2/token and /v2/devices/deviceID/actions endpoints are all the same
Also is there anything different with the mdns search request? Currently we are querying for _bond._tcp.local
Since we donāt have a Smart by Bond device we have to do this integration blind.
Yes it will, and thatās right, the single ID is always 1.
Assuming
/sys/version,/v2/tokenand/v2/devices/deviceID/actionsendpoints are all the same
They are. Weāre striving to make the API identical to make integrations easy to implement.
_bond._tcp.local
Smart by Bond and all Bond Bridges are the same here, as well.
Sorry i meant discovering devices using the /v2/devices endpoint (which i assume returns a single device).
Yeah, it responds in the same way, with a hash and a list device ids and their hashes. In this case, itās a single-element list, and the single device ID is always 1.
Thanks for clarifying jacob. Sounds like we donāt need to do anything.
How do we market āsmart by bondā to our customers? Iād like to push them to those products but canāt seem to find any information about them anywhere on the internet.
