I was previously on Home Assistant Core 2023.4.6, but the upgrade to 2023.5.3 breaks my integration. Restoring a backup from a week ago (before the upgrade) fixes the issue, but as soon as I re-upgrade, the issue comes back. I didn’t re-upgrade by restoring a problematic backup, I just performed the normal firmware update again and it breaks it.
I don’t have specific error messages since I’m currently running from the working backup image with 2023.4.6, but I can upgrade again to get a specific error message if needed.
Before I go to all that effort, I just wanted to ask, are there any known issues with the Bond integration with the newest version of Home Assistant?
I’m running a Bond BD-1000 with firmware version 3.12.7 on HA version 2023.5.3 without any problem. It would be nice to know what error(s) occurs on your HA install?
Logger: homeassistant.config_entries
Source: custom_components/bond/init.py:98
Integration: Bond
First occurred: 7:05:44 AM (1 occurrences)
Last logged: 7:05:44 AM
Error setting up entry Bond Bridge for bond
Traceback (most recent call last):
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File “/config/custom_components/bond/init.py”, line 98, in async_setup_entry
hass.config_entries.async_setup_platforms(entry, PLATFORMS)
AttributeError: ‘ConfigEntries’ object has no attribute ‘async_setup_platforms’
The upgrade also messed with some random webhook I had that I don’t even remember setting up. This is probably unrelated but I just wanted to mention it anyway.
Also, something interesting to note… The Bond integration says it’s a custom integration in Home Assistant. Most of my other integrations don’t say that, unless they were added in HACS. When I check HACS, Bond is not in there.
Also, if you do a Google search for:
It looks like a TON of integrations for various programs broke with the Home Assistant Core upgrade that came after 2023.4.6. Most of these integrations rolled out an update to fix this issue, but I don’t see a way to update my Bond integration.
I don’t regularly use HA - just boot it up from time to time.
That being said, I follow a couple of integration threads on HA and it seems common - as your Google search revealed as well.
Some folks have posted that this seems to be related.
Thanks for the assistance, I got this working. I was going to ask for instructions on how to delete the custom integration, but I ended up just deleting the Bond folder from /custom_components/. It felt a bit sketchy but I had backups if it didn’t work.
Fortunately, one reboot later, HA detected my Bond bridge automatically, without the custom integration icon on it, and everything went smoothly.
