My Home Assistant will not discover my Bond Pro automatically or manually. After my routers changed, the bond just lost connection even in the bond app. After resetting the network settings on the bridge, it came back into the bond app. I got the IP and Local Token from the app, and also ran a curl command to double check the local token. Other devices discover perfectly. Any ideas?
Are you saying you are able to interact via curl from your computer, but yet the Bond Home app is not working with that Bridge?
It is now working is now working in the bond app. I need help getting into home assistant.
Have you tried reloading the devices in the integration?
Also, removing and adding the device or the integration may help.
Please share the results of your tests ![]()
Hi! I have removed the bridge, and when I try to add it again, it doesn’t discover it.
Have you tried setting up with the IP and Access Token manually?
Yup. I have even double checked the local token with a cURL command.
Is it possible that they are not in the same network/subnet and that the Home Assistant can’t reach the Bond?
Not Sure. My Bond is connected to my routers by Ethernet, and the Mac I run Home Assistant is connected to the WiFi. I have a mesh network, but it discovers other things on the network fine. It worked with my old routers so I am not sure.
A good test we can run is to set the Bond to the same Wi-Fi the Mac is and see if it changes something.
Before listing the steps to do it, if you feel more comfortable, you can perform a backup, this article explains it very well.
To do the connection changes:
- Remove the Ethernet cable from the Bond
- Wait for a Wi-Fi network to show up with the SSID “Bond Config [YOUR BOND SERIAL]”
- Connect to this network and get back to the app
- The app will lead you over the whole Bridge setup again, but I guarantee you that you won’t lose any configuration
- During the setup, the app will ask which Wi-Fi network you want to connect your Bond to, select the same one the Mac is
- Wait for it to sync and let me know if it shows up in the Home Assistant
Thank you!
Hi! Sorry for the long wait, I have been busy lately. Unfortunately, even after connecting to the same wifi network, it won’t discover it. Even after wiping/hard reseting the bridge, Home Assistant wouldn’t discover it
Remove the BOND integration in HA. Restart HA and add the BOND integration.
Let us know.
I recently got a Home Assistant Green, and Bond has worked fine!
