There’ve been some questions on how to set up schedules and groups in our integrations, so I’ve decided to put together a brief guide.
For Google Home:
First things first, make sure you’re on the V2 Bond app, named “Bond Home” in the App/Play Stores, and make sure you’ve got the V2 Bond skill in the Google Home app (it’s also named “Bond Home”).
^ You could group devices by room, and voice commands such as “Turn on all living room fans” should work. More customized control can be done via routines. Let’s build a quick routine: tap the “Routines”.
^ “Manage Routines”
^ “Add a Routine”
^ Set a custom voice command or a time and day, and set a voice control or multiple voice controls to trigger. That’s it!
