Fireplace RFP8 patch SIGNAL command
I have a request from HomeSeer user to patch SIGNAL for TurnOn command to set ‘reps’ to 5 (following https://us1.discourse-cdn.com/flex019/uploads/bond1/original/1X/557412d4d7c2194df21e2025cc488081fe8ac5d2.jpeg)
Problem I’m facing - the SIGNAL command doesn’t seem to be available via API.
Any request like “http://192.168.1.26/v2/devices/47cc0984/commands/6ad2563a”
returns “signal”:{“_”:“00000000”}, and requests like “http://192.168.1.26/v2/devices/47cc0984/commands/3276e6ea/signal”
returns empty string.
FYI, I don’t own the fireplace, I’m testing using my own Bridge with my devices.
I see the device you’re testing with looks like a Shade type device from.your screenshot.
I noticed someone else before not having a Signal endpoint on Shade devices, but the Bond staff explained that not all devices will have a meaningful Signal endpoint:
The first long form document screenshot you referenced does look accurate as to how the reps would be changed on a device that has a meaningful Signal endpoint (such as a Fireplace).
