DD7402H remote for Blindster Deluxe Bamboo shades
Bond seems to recognize commands from the remote DD7402H (Pro Design models has related models DD7402HB, DD7412H, DD7412HB) just fine but sending the commands from Bond fails. This is similar to other issues where FSK modulation seems to be used and some people seem to find workarounds but the exact steps are unclear.
The FCC entry is here (FCC: 2BMF4DD7412H). Do I have any hope of making this work with Bond?
I’d appreciate any thoughts you might have.
Solved! Adding it as a Dooya Bidirectional shade works. Follow the instructions and press the left P2 button on the back of the remote above the battery compartment when prompted.
The Dooya Bidirectional workaround is the key detail here — that pairing step with the P2 button is easy to miss if you are just poking at the app menus. Given that Bond reads the DD7402H commands but can’t transmit them, that lines up with the remote using a different protocol than Bond’s default shade templates. Adding it under a bidirectional Dooya model makes sense as a workaround since it uses a compatible command set. Worth noting for anyone with the DD7402HB or DD7412H variants that the same approach may apply, though I would test one shade before committing to a whole room.
The P2 button detail is exactly what trips people up, so thanks for flagging it. The DD7402HB and DD7412H variants are worth mentioning too, since the same bidirectional Dooya path likely covers them. Testing a single shade first is sound advice, especially with Bamboo shades where motor firmware can vary between batches. If Bond still rejects a command after pairing, re-checking that the remote is in the right mode before pressing P2 usually helps.
