I just got a new Casa Vieja fan with remote with FCC ID CHQRH787T which I am not able to pair with my Bond Bridge PRO using any of the templates or even manually recording the remote. There was a forum topic from 2021 suggesting to manually adjust the frequency before configuring using an advanced setting that no longer seem to exist. Can you please help?
Forgot to mention:
Bridge model: BD-1750-PRO
Firmware: v8.4.1
Hey @gchapiewski !
I searched your FCC ID and looks like your remote control operates in 303.947 MHz.
Here are the steps to set your Bridge to listen to this specific frequency:
When you are creating your device, after choosing a command to record, you get the following screen:
Tapping on Advanced you’ll get this screen:
Tap on Frequency, which will take you to this screen, where you can tap the desired frequency (in MHz):
May worth mentioning that you need to tap
Done. Then the app will take you to the previous screen, which should be like this now:
Tap
Saveand follow the process, you should get the screen suggesting you the remotes that may work with your device.
Feel free to reply here or send me a DM if you still face any issues.
(Screenshots are iPhone, but the process is similar if you are using Android)
Thank you!
