Bond Sidekick Function
I just set up a Bond Sidekick to operate a specific channel of shades in an office. I placed the sidekick in 8-key mode so that I could set specific presets for each key press. The key press programming is as follows:
1 - Open
2 - position to 20%
3 - position to 50%
4 - position to 80%
5 - Close
6 - Hold (aka stop)
7 - Close
8 - Open
The issue that I am facing, is that most of the time when I press 3 - 50% for instance, it will go all the way down to 100% and then back up to 50%. If I press 2 - 20% after that it will go up to 0% and then back down to 20%.
Am I doing something wrong on the programming side in Bond or is this a known function of how this should work?
Hi @jmart94 :blush:
thanks for the detailed description.
The “set position” feature may vary slightly depending on the shade model and manufacturer.
I’d like to check our internal logs for better debugging.
If that’s okay with you,
could you please share your Bond-ID with me via DM?
This is indeed how it works for technologies like Somfy RTS which do not have a discrete “set position” command, and we need to emulate it through timed commands. That said, it should be some of the time, not most of the time: we only go all the way to the rail after there’s some uncertainty like after ~5–8 operations in my experience. (This assumes you are using RTS or another deadreckoned slider in the app. Igor indeed can check.)
