My first impression is very positive. It paired to all the Somfy blinds (21 groups) (unlike the regular units) right off the bat and reached them all from a central location. It also paired well with one fan but having an issue with the last fan, it seems to learn the codes but can’t get the codes to operate the fan from the bond pro, maybe that frequencydoesn’thave as good of range as the Somfy.
Very happy that it solved my main issues of how many somfy blinds it could pair with and how far away they are.
POE works great, but it still wanted to connect to WiFi, shouldn’t it just use the ethernet cable to talk to the network?
One other small note, the case is too opaque to tell what the led rings are, almost need a clear plastic portion gor that top circle.
