Bond on Mesh WiFi
I upgraded my WiFi to Netgear Orbi (https://www.netgear.com.au/orbi/rbk50.aspx) - now I have Orange Bond.
I found a couple of related posts, but there’s no solution:
Interesting enough I managed once to re-connect (was a pain), it was working for a few days.
Today it’s orange again - and doesn’t reconnect.
I tried Green Reset, tried to switch my Google Pixel to Bond config AP - same result - it says new device found, I click “add to account” - in a few second it says “Lost Connection”.
Interesting, when I manage to get to the WiFi selection page - my FiWi is not even listed there.
Help!!!
[EDIT]
It says there’s FW update - but I can’t update if it doesn’t connect…
Hey @alexbk66,
Sorry to hear that.
Since you’re having issues completing the setup flow using the app, can you try to use the Web GUI? This article can you help with it.
Let me know if you have better results.
Thank you @endy, after rebooting the Orbi router I managed to connect again.
This Orbi seems very strange - some devices work without problems, some have issues.
I guess it may be caused because the Orbi exposes only one SSID for both 2.4 GHz abs 5 Ghz,
then Orbi decides which frequency to use for each device.
I can’y even understand how it works.
Ok, it’s orange again, so I tried to follow your instructions (the link), at the point
  • Select your WiFi network ( Select your Access Point )
I don’t see my network. That’s the problem I already described.
Note that other devices are connected to the network.
Hey @alexbk66
The router I have also exposes only one SSID, I think it’s really annoying, but it was too expensive to change it again for some time, unfortunately.
My Bonds works as expected, so it probably is something else.
Thanks for testing the Web GUI, it helps to isolate the issue.
One possible cause is the Wi-Fi channel, usually the router uses “automatic” and change the channel to the less noisy one.
Jacob mentioned it in this post saying:
Good catch! It’s only looking at channels allowed in the USA (1-11). We need to make this configurable and make the app configure it before setup, now that we’re starting to sell outside the USA.
Can you test setting the router to use one of the 1-11 channels?
I used this Wifi Analyzer app on Android devices to see the noisy channels on my place and select the best one.
If you have a Mac computer, you can check the channels opening the Wireless Diagnostics, ignoring the Wizard and going to the Window menu and selecting Scan (or press option + command + 4).
This is the devices I’m used to use, but for sure you can do it with iPhones and Windows computers too.
Let me know if it helps you!
Have a good weekend.
Thank you Endy, as soon as I changed the channel - Bond was blue again.
I was ready to throw the Bond from the window and/or return $500 Orbi router.
