Hi everyone.
I’m installing several lights and fans in my home and purchased the Lutron Caseta switches which all hardline to my lights and fans, but also integrate with Google Home.
I discovered though that two of my fans are not pull chain, but are controlled through the remote only. I still want smart home integration so I purchased Bond to do that.
Here’s the question though. The wall mounted remote the fan comes with is ugly and I would love to use two Lutron Caseta switches (one for light control, the other for fan control) so that all my switches are uniform. Is it possible to power these switches on the wall and that when a button is pressed, they trigger an “on” command to my Lutron Hub, which talkes to Google Home, which talks to Bond?
Or any other switch (or two) that would fit in a gang slot and be able to be programmed to trigger bond. I’m assuming smart things may do this when integrated.
