In homekit I am not able to see any control other than a simple light bulb, ‘on/off’ switch. when i operate the light switch it appears as a dimmer slider however what does that control?
Is there a way to at least add fan and/or flame height to the mix? almost presenting as fan speed similar to how ceiling fans work with bond bridge & homekit?
@merck – I have a regular Bond Bridge and am trying to enable HomeKit support for Somfy Shades – however I only see Alexa, Google Assistant and SmartThings in Integrations and no mention of HomeKit under the bridge settings > Advanced Settings. Any pointers?
You’ll need the v4 firmware but it’s not out yet for BD-1000 Bond Bridge. Working thru an issue with the chip vendor. It is available now on Bond Bridge Pro BD-1750.
I have the new 4.x beta firmware and HomeKit is working great with my Somfy RTS roller shades!
Do you know if there’s a way to trigger the shades to scroll to the “favorite” position that’s pre-programmed via the ‘my’ button? Would asking Siri to set the shades to 50% accomplish that?
You can just specify the % that you want. I think you can do this via our forever-beta HomeKit integration.
Note that for the special case of RTS, the Hold and Preset actions send the same RF signal. So you could also use the Hold action (“Stop”) if it be exposed on your integration.
