Bond and RC300 Integration
I recently purchased a Bond Bridge - it works great (for the most part) with my ceiling fans, but not dice with my RC3000 for my Heat and Glo. Anyone have a workaround for this? The unit is not a milivolt system (I have one in the basement that is and already have a work around for that).
Any help would be greatly appreciated. I also emailed Bond asking them when, if ever, they will support an RC300.
Thanks
JD
No workaround yet. It would be nice if Bond addressed this.
Does this listing look like your remote?
It can be helpful to the Bond staff when they come through here if we provide the FCC ID for them.
(If that’s the correct one, it is showing as unsupported, as you have mentioned / found out, in Bond’s database).
Model: RC300
FCC ID: ULE-RC300
IC: 6732B-RC300
It is listed at “not supported” on the Bond website.
I don’t own a Bond yet but if they can get RC300 integration working I’ll be purchasing a Pro.
To that end, here are captures from a Flipper Zero that I can replay (via the Flipper Zero) and will successfully control my fireplace…
https://drive.google.com/drive/folders/1SuHq2dyFYdO7asfM45iWyDiI9GnY0Q2L?usp=sharing
