This question is similar to this one (BOND Wifi Hotspot is still visible?). Because my Bond Smart Bridge is on an isolated network, it never connects to the Bond Cloud which means it never seems to exit setup mode (even though it is fully setup locally) and the config wifi ssid continues to be active. I’ve downloaded the latest alpha firmware (2.29.13-alpha) because the latest stable is older than the version mentioned in the above post. However, even with this version I don’t see a way to to exit setup mode in the API docs (http://docs-local.appbond.com).
So simply, how can I exit setup mode without connecting to the cloud?
