jgbond1
November 12, 2019, 11:19am
1
I received the email that the v2 API was now available and I used the new Bond app to update the firmware on my Bond device.
ᐅ curl -i http://192.168.1.X/v2/sys/version
HTTP/1.1 200 OK
Content-Length: 142
{"target":"snowbird","fw_ver":"v2.9.5","fw_date":"Thu Nov 7 21:44:45 UTC 2019","uptime_s":11359,"upgrade_http":true,"api":2,"_":"5a50769f"}
I retrieved the token from the Bond app and attempted to use the API:
ᐅ curl -i http://192.168.1.x/v2/devices -X GET -d "{\"_token\": \"----------------"}"
HTTP/1.1 401 Unauthorized
Content-Length: 0
ᐅ curl -H "BOND-Token: -------------------" -i http://192.168.1.53/v2/devices
Content-Length: 0
I must have missed a step. Any suggestions?
jacob
November 12, 2019, 4:41pm
2
Well, it looks like all your requests are formatted properly, so the token must be wrong somehow.
I recommend you power cycle the Bond (to unlock the token) then request the token via curl (curl -i http://192.168.1.x/v2/token). Is it the same as you got from the app?
We’re thinking about allowing disabling of token authentication on trusted networks, that should simplify this process…
jgbond1
November 12, 2019, 6:12pm
3
Success! Rebooting the BOND generated a new token, and now all of my bond devices are in home assistant. Thank you!
jacob
November 12, 2019, 8:46pm
4
Good to hear you got it working! Maybe the app had a wrong token? Does the app display the correct token now?
FYI the token should only change if the Bond has its database erased.
