Trying to dig up the release notes for v3.21.6.14 that has just dropped in my app.
So, the v3.21.6.14 is a temporary version. If you hit “update” again you should get v4.7.1.2:
Release notes for v4.7.1.2:
Two-Step Upgrade
BD-1000 users currently on v2.x or v3.x will need to upgrade twice:
Old Stable v3.21.3.6
Temporary v3.21.6.14
New Stable v4.7.1.2
What’s Changed since v4.6.5
- Fix longstanding issue that caused general instability on BD-1000 and BD-920. We believe this may improve the reliability of Groups and Schedules.
- Fix issue where Sidekick information did not update on the app screen. It now updates live.
- Blink light ring when Virtual Remote Control is used.
- Awning support for SunPro (RMS5), correcting Open/Close directions. Applies only when subtype is set to “Awning”.
Thank you, just before I upgrade, can i confirm it’s possible to revert to Old Stable if things were to go sideways?
Basically, yes. You should be able to “undo” back to v3.21.6.14 from the firmware update screen. This is essentially the same as the v3.21.3.6 version just with a provision for allowing the v4 update.
